Civic/Integra rear suspension compatability?
has anyone on here ever put OEM DC integra suspension on a 96-200 civic before? and when i say suspension i mean the full shock and spring setup...thanx.
the real reason why i ask because i actually did it and made it work and im wondering if anyone has encountered any problems by doing so?...
Re: Civic/Integra rear suspension compatability? (I got a honda)
i did on my car i did full front and rear. U will need to get camber plates for the front after and i use my stocks and struts cause they are skunk 2 coil overs. other then that direct swap. Mine was a 93 intega 4dr tho.
Re: Civic/Integra rear suspension compatability? (ricefourlife)
hhhmm i wonder if 4 door DA suspension is different in the rear then a DC?..
this was pretty much a direct swap but the rear needed some major fiddling...i think ive seen it before and someone might have used washers to make up for the space between the fork?..i just tightened it as much as i could with as little space STILL there..
but drives great, no problems...
NTGR8D
03-07-2005 09:17 PM
