Civic Ex adjusting rpm
I just picked up a 2000 Civic EX and the rpm are a little low when the car is in drive. I know there is a screw on the throttle body which I turned already but it didnt realy do anything. Do I have to mess around with the throttle cable? I believe on my 93 I just turned the screw and it worked. I heard that the 2000 has an iacv that contols the rpm. Anyone know the correct way to raise the rpm? Thanks.
Re: Civic Ex adjusting rpm (93civicsedan)
your rpm is low when the car is in drive?? u mean in gear but the car is still at idel,right?? anyways..only adjust your throttle cable only when it is a bit loose..also..u can try to clean your iacv with brake cleaner..
Jimi Hondrix
05-22-2017 07:04 PM
dpfi_1.6EFktr
09-20-2007 12:03 PM
