Civic eg no power? HELP!!!
I just recently bought a 95 Honda Civic hatchback that was crashed from the passanger side quater panel. I bought it because I wanted to use it to fix my 92 eg si. When I bought the car the guy went to turn on the car to show me that the motor and everything was good but at first there was no battery. The guy changed the battery to start the car. There was no power at all in the car (hazards) (lights) (horn) (beeping sound) etc. I took his word for it because he did alot of work to the motor and he showed me the receit. New head gasket, new timing belt, new distributor, and new starter. So I bought the car and I've been trying to turn on the car to see if the motor works but I get no power. I bought it because he guaranteed the motor works and if it doesn't he will give me back my money. I checked for blown fuses, checked the connections, and the main relay. Does anyone know what may be wrong with car? If anyone knows what's wrong please let me know asap cause I need to move the car.
Re: Civic eg no power? HELP!!!
Did you check the 80 amp fuse? Is the battery ground good? Power direct from the battery also goes straight to the ABS relay center and its own fuse. Check continuity.
Thanks for trying to help i figured out the problem for some reason the guy that i bought the car off of he had the fuse box cable going to the ground and it was suppose to be on the positive..
CRXguy_88
02-22-2012 07:49 PM
