civic eg, bog at low rpm, stutter/ missfire & sometimes backfires
civic eg has no codes, stutters from 1.5k- 4k rpm especially if accelerating slow, bogs if i floor it. when feathering the throttle, it back fires. no smoke.
put a new o2 sensor in and it turned black
im thinking too rich,
any ideas?
any ideas?
Re: civic eg, bog at low rpm, stutter/ missfire & sometimes backfires
i havent timed it, but ive adjusted the dizzy and it still stutters no matter what position... sounds ghetto, but its what i have to work with. I'm replacing the cat next and then going from there
changed the plugs, it runs a little bit smoother, but the plugs are fouled with fuel... it seems its dumping fuel in. I changed it to a ek DX header/ cat and now it blows smoke .... Im guessing from fuel saturation
I have NO codes.
I have NO codes.
I changed the header because its a known good cat... the one before is not known if its good.
motor is bone stock
i think my problem is specific to fuel dumping. it gets horrible gas milage as well --- probably due to the fuel dumping
motor is bone stock
put another stock P06 ecu in and same symptoms.
why would this thing be running SO RICH
I've been having the same symptoms and I can't adjust the timing either so I move the dizzy around. I gotta get a lower timing cover then Im timing it asap. I'm like 98% that's what it is
you think its a timing issue?
I have adjusted my theory to it being a Spark issue.
I have new plugs and cap
maybe the coil may be dying
it looks like the timing is on. I have the white mark lined up with the pointer and the "up" is lined up with the distributor ear, so my guess is its a bad dizzy
i dont have a timing gun to time it, and i dont think it would act so horrible no matter how advanced or retarded i moved the dizzy
The Grumpiest
Post #16 seems to suggest otherwise. You don't need a timing gun for mechanical timing. Check the FAQs for How-To's.
And AGAIN, when was the last FULL tune up you've done. Plugs and wires are not a full tune up.
to give you an idea, the last time the car was driven was about 2 years ago
