Civic doesnt stay on?
i turn it on and 2-4 seconds later it turns off? my friend says its the fuel pump about to check it out. if its not the fuel pump what can it be?
Re: Civic doesnt stay on?
Make sure it's not just a cold start. Turn it on and when it turns off try turning it on again. Mine was doing that just a week ago.
thanks for the replies. i turned it on more then one time and its always the same result. it starts of normal and it dies off slowying and the oil and battery lights illuminate. battery is good replaced it not so long ago.
Give some background.
Has this engine ever run? Is it a new engine install?
CEL codes?
Are all sensor connectors matched to the correct sensors?
Is the mechanical timing correct?
Do all 4 spark plugs have bright white spark?
Are the plug wires installed in the correct firing order on the distributor cap?
CEL codes?
CEL codes?
CEL codes?
Dont know how to put out CEL codes.. Still a newbie.
yes, yes and yes.
has been my daily driver for 2months now.
What car/engine?
See Codes sticky at the top of the forum. It shows how to pull codes.
Does the fuel pump prime for 2 seconds when the key is turned from off to ON(II)?
Checking on how to pull codes right now.
"Does the fuel pump prime for 2 seconds when the key is turned from off to ON" by this you mean the sound the rings when your turn the key right?
The fuel pump makes a low humming or buzzing noise when it runs. It's located in the fuel tank, so the noise comes from the rear. If you are unsure, remove the fuel fill cap and put your ear to the fill hole while a buddy turns the key from off to ON(II).
yea making sure thats what you meant i havent tried that waiting on my friend to swing by. would the IACV affect this? my car rpms sit at 1 when car is on? sorry im still new to this ! its my first car and still learning alot.
okay so my buddie came by already and check the fuel pump and its good! so whats next on the check list?
i did almost everything i ran out of ideas?! my other buddie of my said its the pump still. it primes but turns off. so going to change that and see what happens..
How much of the spark plug is black? Is it an oily black or a dry black? If the outer part is black and the inner porcelain is beige/brown then that's pretty normal. If the whole plug is a dry black, then it's either running rich or the plugs are too cold (probably running rich, though). If it's wet at all though, that's a very bad sign.
