Civic Coupe 96-00 in USA
Hello Guys,
I´m new here and from Germany . I drive a Honda Civic 2dr Coupe Ej6 with the D16y7 engine with 105 Hp . I want to know if the engine and Model Ej6 exist in the USA ?
I know that the Ej8 and Em1 ( SI )exist in the Usa , right ?
Re: Civic Coupe 96-00 in USA (96dxpower)
Ok thanks ,
what is the correct indication for the ej6 and is this the same engine ? ( d16y7 )
What is the difference between DX ,EX .....
If I want a Catback exhaust system for my Ej6 . For which indication I must looking for ?
Re: Civic Coupe 96-00 in USA (NEXRILLIS)
here in the states it would be 96-00 civic.. dx ex lx etc are the trim levels (whatever you want to call them).. dx is more of a basic standard model.. ex are more "sporty" "luxurious"
D16Y5
Displacement (cc): 1590
Power (bhp@rpm): 115@6200
Torque (ft/lbs@rpm): 104@5400
Compression Ratio: 9.4:1
Bore (mm): 75
Stroke (mm): 90
Cam Design: sohc
VTEC?: yes
OBD: 2
Year(s) Produced: 1996-2000
In the following car(s): Honda Civic HX
D16Y7
Displacement (cc): 1593
Power (bhp@rpm): 106@6200
Torque (ft/lbs@rpm): 103@4600
Bore (mm): 75
Stroke (mm): 90
Cam Design: sohc
VTEC?: no
OBD: 2
In the following car(s): Honda Civic DX/LX/CX
D16Y8
Power (bhp@rpm): 127@6600
Torque (ft/lbs@rpm): 107@5500
Compression Ratio: 9.6:1
Bore (mm): 0
Stroke (mm): 0
Cam Design: sohc
VTEC?: yes
OBD: 2
In the following car(s): Honda Civic EX
D16Y5
Bore (mm): 75
Stroke (mm): 90
Cam Design: sohc
VTEC?: yes
OBD: 2
D16Y7
Bore (mm): 75
Stroke (mm): 90
Cam Design: sohc
VTEC?: no
OBD: 2
D16Y8
Bore (mm): 0
Stroke (mm): 0
Cam Design: sohc
VTEC?: yes
OBD: 2
saywhat
12-13-2010 12:06 PM
MikeExt
04-22-2002 02:26 PM
