Civic 92-95 Mpfi Swap?
Hi, I tried to search but no results for my 92 Civic.
Is there any guide, how to swap my d15b2 obd-1 i think to mpfi? Someone sayd I need an d15b7 ecu, d16 sohc vtec intake manifold ... ? Who knows exactly what I need ?
Thanks!!!
Thanks!!!
Re: Civic 92-95 Mpfi Swap? (GermanCivic)
The 1992 Civic has a d15b7 which has mpfi. Did you swap a d15b2 from an EF into your 92?
edit: I see you are from Germany... what I said may or may not be correct about European Civics.
Anyway, you will need a d15b7 ecu, d manifold with 4 injectors and fuel rail setup etc, and the wiring will be a pain in the ***.
Re: Civic 92-95 Mpfi Swap? (DanW)
Ok, if I can get wiring diagram from both, i could do the wiring, or what do you thing? swapping the "old" d15b2 to mpfi is easy... I read many how to´s ....
thanks
thanks
1 Post
The only difference between the D15B2 and the B7 is indeed the intake manifold.
Just get the mani and the B7 ecu and wire the 2 extra injectors. I thought that only wiringmod necesairy.
It cant be done but it times a lot of time for a minimal result. On average you gain some 10hp.
I looked into this swap to, but decided on a mini-me.
shervang9
28
03-16-2011 12:00 AM
humphreyz
12
07-03-2005 08:11 AM
