Civic 92-95 EG6 fan not working radiator problem help ASAP
I have a civic 92 dx witch a stock motor d15b7 I think my fan sensor doesn’t work the fan will not turn on and my car will overheat. I need to put the fan direct to be working all of the time in the meantime I could fix this problem help please I need this car to go to work
Re: Civic 92-95 EG6 fan not working radiator problem help ASAP (kos99ngel)
u could hook up a peace of wire to the plug to the fan swithch and it will come on with your key and turn off when you turn your key off
check fan relay
have you change the thermostat
is there any leak
check the thermostat sensor
is there any leak
Well this is why I think it’s the fan. When it was overheating last week I pull into a gas station the needle was all the way to the top. I open my hood and the fan wasn’t spinning I turn off the car water was coming gout of the reservoir tank all of the water that was in the radiator came out of the reservoir tank with lots of steam. Fan was not spinning I added water when I turn on the car the fan started spinning I notice sometimes when I turn it on and off the fan will start spinning trying to cool down the car
Re: Civic 92-95 EG6 fan not working radiator problem help ASAP (t_dizzle23)
I try wiring up directly to the battery just for right now but the fan wouldn’t spin
D Tranny Guru
remove the connection at the fan switch on the thermostat housing, insert paper clip, turn key to "on".......fan should come on.
If it does, replace the switch on thermo housing, 22 or 24mm I believe.
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">remove the connection at the fan switch on the thermostat housing, insert paper clip, turn key to "on".......fan should come on.
If it does, replace the switch on thermo housing, 22 or 24mm I believe.</TD></TR></TABLE>
^^ If the relay is working he should also hear a "click" right?
If your fan doesnt come on you can jump it like others have said to see if its working. If its not working, you would need to replace it of course.
Re: (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">
If your fan doesnt come on you can jump it like others have said to see if its working. If its not working, you would need to replace it of course. </TD></TR></TABLE>
I try to wired the fan directly to my battery fan wounl't turn on. but when i unlock my car with my car alarm it turns on and it spins for a little bit
phaphon
12
09-15-2010 09:37 PM
