Chipped ECU on a 99 SI (B16A)
I have a chipped ECU on my SI and I can't figure out what's going on and why my car wont crank? I bought a OBD2b to OBD1 jumper harness and it still wont work? I'm stumped on this and it's new to me lol (Ecu/jumper harnesses).
Re: Chipped ECU on a 99 SI (B16A)
When i bought the car... the guy said that the motor (B16A2) was locked up. So I bought a B16A from my boy and the chipped ecu is tuned for that motor. So i got it and it will not crank with the chipped one. I have the jumper harness to make it work.... seems to not be. Also, before I put the chipped ecu in I had a knock sensor issue. I did the chipped ecu to delete the knock sensor all together.
The Grumpiest
Don't really think it's the ECU but we need to know what's done to teh motor that it requires a chipped ECU.
Is it a no crank or a crank but no start?
try to get ahold of a p28(obd2) and try starting with out the jumper or the chipped obd1 ecu. knock sensor wouldn't stop it from starting/cranking and yes it can be disabled when the ecu is chipped(if that was put on the chip).
so a chipped P30 that's fine as long as it works did you try taking the chip out ? and can you get an obd2 p28 (so no jumper) and try that
I figured out the whole knock sensor thing, my brother helped me on the B16A swap and he routed the harness wrong and confused the K/S with the CPS. So that was awesome! The ecu thing is about to be refunded as well... I don't think it's necessary.
