check engine in ZC motor
hello
im asking for my friend.
the check engine light is on and we try to find what cause the problem.
the car is a civic hb 93 ZC CHASIS...
maybe its the lamda?
thanks
roy - israel
thanks
roy - israel
Re: check engine in ZC motor (roy civicHBturbo)
When a problem exists in your engine bay usually a sensor will energize or deenergize, opening or closing a circuit, and will be recognized by your ECU. Once your ECU sees this it will send voltage to your dashes check engine light. Upon completing this circuit the engine indicator is will illuminate, signaling to the driver of a fault existing.
Please send more info about what's going on with your engine. Anything! The last time you tuned it up... If it sputters... Personal modifications... Anything.
