check engine light solution needed
Re: check engine light solution needed (el_toro_de_magnifico)
yes i have tried that and i have also tried using a seperate led light to check but still t wont work. anyone?
1 Post
Get a wiring diagram and start checking your powers and grounds. It could be the ecu but that is a pretty expensive guess don't you think?
Re: check engine light solution needed (JDM-97CX)
how could you tell if the ecu is damaged?
update! now my car wont start! i dont know why! there is gas, engine rotates then it feels like its gonna start but then it doesnt. battery is fine. also, i think i can hear the exhaust firing(like when a car is about to start) but it just doesnt get started.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el_toro_de_magnifico »</TD></TR><TR><TD CLASS="quote">how could you tell if the ecu is damaged?
update! now my car wont start! i dont know why! there is gas, engine rotates then it feels like its gonna start but then it doesnt. battery is fine. also, i think i can hear the exhaust firing(like when a car is about to start) but it just doesnt get started. </TD></TR></TABLE>
throwing a check engine light? check for it.
j/k
Try a different ecu maybe.
j/k
sometimes even corrosion on the terminals can cause bad connections on the relay.. you can test it with a multimeter or just get a new one and hope thats your problem
ballbuster4u
17
09-20-2019 07:01 AM
RCautoworks
12-20-2002 02:07 PM
