check engine light after AEM cold intake - sensor problem
I get a CEL when I start driving after I've installed an AEM Cold Intake into my Del Sol 96 B16A6, there was no place for the sensor previously connected into the stock filter pipe, so I've left it hanging with the sensor connected to it. I get a CEL only after I drive from a stop and it stays on. Do I need the sensor anyways? How to get it to go off? Thanks.
Re: (sharik)
ok i've just done that, i've drilled a hole in the coupler between the two pipes, but i was surprised to see the CEL go on again, what could be the problem? note that its only when i start driving
Re: (fdavie)
not sure because basically there's no CEL when i start the engine, only when i start driving. i thought it was related to the IAT sensor, but now after installing it back i am confused
Re: (fusebox15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fusebox15 »</TD></TR><TR><TD CLASS="quote">not sure because basically there's no CEL when i start the engine, only when i start driving. i thought it was related to the IAT sensor, but now after installing it back i am confused </TD></TR></TABLE>
The computer stores the code; the engine light doesn't have to be on when you retreive the code. And while it's probably something to do with the IAT, knowing exactly what the computer thinks is wrong will help you diagnose.
Re: (fdavie)
here it is: http://www.youtube.com/watch?v=8_u4VuBEy9w
so is it 24? or 33? or 52?! none of these is on this list https://honda-tech.com/zerothread/1901557
It does look like 23. But how the hell did he bump the connector installing an intake? I can barely get my hand back there if im trying! haha.
Re: (fdavie)
yes I installed the intake, but right before I did, honda installed a Hondata intake manifold gasket, thats when the manifold with all pipes and plugs go out, could've they forgot to plug it back?! I am going to check
Re: (fusebox15)
i installed a short ram intake...and had a cel also....after u instaled the intake..did u let ur car idle for 10 minutes? your ecu has to recalculate air/fuel after the intake is installed...if u drive it immediately after installing...ur gonaa throw the computers calculations off and possibly trigger cel. also...since i live in canada..our winters are cold...and even with my short ram...when winter temperatures started setting in...i had a cel come on for 2 days because of the cold, denser air. so that could be a possiblity too if ur in a colder state.
Re: (fdavie)
damn right, they left the knock sensor unplugged, and not only unplugged, but its also broken! I am going back soon to sort it out that little sensor costs about 150$
Modified by fusebox15 at 7:47 AM 12/25/2007
Ok its sorted, they gave me a new one
Modified by fusebox15 at 7:50 AM 12/25/2007
TypeRInNeed
12-28-2001 10:07 AM
