check engine light
check engine light
just did a b20 in a eg and it runs fine except that the check engine light is on... i was told to stick a paper clip into my ecu and listen for beeps... does anyone know what that is suppose to do?
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: check engine light (NAEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAEK »</TD></TR><TR><TD CLASS="quote">just did a b20 in a eg and it runs fine except that the check engine light is on... i was told to stick a paper clip into my ecu and listen for beeps... does anyone know what that is suppose to do?</TD></TR></TABLE>Just a side note, never stick stuff in the ECU. Under the dash on the passanger side there will be two loose connectors, one 2pin and the other is a 3 pin. Jump the 2 terminals of the 2 pin with a paperclip or wire and turn the ignition to the ON position. The CEL will blink to indicate the diagnostic trouble code. Long flashes = 10 short = 1 so for example one long flash followed by 2 short is 12. If there is multiple DTC stored there will be a pause between the seperate codes.
Darth ModerVader
