CHeck engine
CHeck engine
My light when i start my car blinks every second or so when my car runs, this just started late tonight. It was fine all day, but when i started it up that car had a lot less power, it also has a rough idle now? What should I check
Re: CHeck engine
If your car is a '96-'00, take it to Autozone and have them pull the code(s) for you. If your car is a '92-'95, check out this link and do what it says to pull the code(s):
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Re: CHeck engine
I just read them myself since my brother has an obd II reader, the codes were random misfires, cylinder 1 misfire, cylinder 2 misfire, and cylinder 4 misfire? Now i was told to get a set of spark plugs should i try that
Re: CHeck engine
yea when its flashing while driving the car should be shut off immediatly,, cant be exact but its gotta do suttin with your emmisions,, get it scanned and get a code
Re: CHeck engine
Funny that this happen to you. I just got he same problem last week. Misfire on cyl 1, 2, & 3 for me. I haven't got the chance to look at mine yet, but let me know once you find the resolution for yours.
Re: CHeck engine
Re: CHeck engine
I've had NGK's those are the ones that crapped out on me, I now have Bosch's and work fine. If you want to stick to OE then yeah i guess get NGK's
Re: CHeck engine
well as long as they'll work enough to where you can decipher if that was your problem or not, and then when those crap out on you here soon you can save some cash and get some good ones...im running Denso Irridium's in mine but theyre like 75 for 4 lol, ive fouled a lot of the "unfoulable" NGK's so im not a fan.
Re: CHeck engine
hes either jumpped timing from a streached belt or dizzy, when its flashing like that that means ur having a missfire. check timing belt n timing
Re: CHeck engine
ngk iridium are nice if you can spring for 7.50 a piece..... i feel bad though cuz i had to get new wires and all they had are autolites, crappy i know.
Re: CHeck engine
Did you ever get your issue resolved? Fyi, I bought some oem spark plugs, wires, cap and rotor. I swapped out my plugs first, reset the ecu and that fixed it for me. Drove my car around for a good 30 min and no CEL. My idle issue went away and car drove great! However I will continue to go ahead and replaced my wires, cap and rotors.
NTGR8D
07-08-2003 08:03 PM
