Cheapest possible practical swap for an EJ7?
Old 10-04-2010, 09:28 PM
Whydid's Avatar
Default Cheapest possible practical swap for an EJ7?
I'd like to keep OBDII. It's a daily driver. D16Y8? I hear B20s are real cheap, but that would necessitate a new trans and such. Thoughts?
Old 10-04-2010, 09:49 PM
SHG_Claudio's Avatar
Default Re: Cheapest possible practical swap for an EJ7?
B20s are solid bro. Let me ask you this. What's your budget, what are your power goals? Any D or B series would be a practical swap. They drop in and some you might need to get more parts to make it work. D16y8s would be the most practical but for a little more you can have more torque and dohc which is more responsive to mods.
Old 10-04-2010, 11:03 PM
GranDaddyPurp's Avatar
stock b20 with a gsr or b16 transmission leave it non vtec, perfect daily driver plenty of torque leave it within its limits and it will last you forever
Old 10-05-2010, 12:17 AM
Crazy Honda Guy
Deetz's Avatar
x2
Old 10-05-2010, 01:31 AM
akamrchubs's Avatar
b20 sounds like a good choice here too
Old 10-05-2010, 02:46 AM
300whpej's Avatar
whats your budget? auto/manual? doing the work yourself/paying a shop?
Old 10-05-2010, 05:43 AM
Jimster480's Avatar
This depends on your budget. the cheapest possible swap is a Y8 or Z6 or a D15B.
A B20 with a B16 tranny is not going to be fast. A GSR tranny would be alot better as the B20 really makes its power in the low end and a B16 tranny is geared to a motor that only makes power in the high end (like a B16).
The plus sides of a D16 is that it will drop right in with no mods, will bolt up to your current tranny, and will only require you to run a wire for VTEC (assuming you get a VTEC Swap).
Also why are you asking about a swap? Did you blow your motor or are you looking for more power? Because a Y8 head on a Y7 block (which is what you should have) will make more power than a Y8 (due to the Y7 pistons being higher compression).
Old 10-05-2010, 08:12 AM
Crazy Honda Guy
Deetz's Avatar
I used an LS tranny with my last B20Z swap in a 96 cx hatch that ran me mid 14's. The B20 engine had so much torque i was always feathering the throttle on launch because any more than 1/2 at any speed in 1st gear would lead to wheel spin.
I always wondered if having a short geared tranny like a B16 would be a good or bad thing, i never did try it before i sold the car after a couple years
Old 10-05-2010, 08:41 AM
Jimster480's Avatar
Ya it would be faster with a longer tranny, as you would be able to actually take advantage of the poweraband. Where as a B16 tranny won't stay in the B20 powerband. you should get some better tires though, as I hold traction on my built D series with 303WHP and 241TQ @ 19PSI.
Old 10-05-2010, 10:15 AM
818ek9's Avatar
yea go b20 great torque and very inexpensive
Old 10-05-2010, 11:35 AM
Whydid's Avatar
Factory stock.
Manual to manual. Paying a shop (I currently don't have the tools/access to tools I used to have).
The engine in EJ7s is the D16Y5, which has VTEC-E. Would I still need to run that wire?
Turns out I need a new O2 sensor, which is $500 plus labor. I thought if I'm going to drop that much cash, might as well consider a swap. I technically already have a Y8 head on my car (Y5 head casting is exactly the same as the Y8, and actually has a slightly better cam and roller rockers), but I don't know what the differences, if any, there are between Y5, Y7, and Y8 blocks.
Old 10-05-2010, 12:02 PM
WhiskeyD's Avatar
$500 for an O2 sensor!!!? Thats ridiculous! I would definitely try some other shops.
Old 10-05-2010, 01:03 PM
jyacoba2009's Avatar
some shop can do it for $120, $40 for the part and $80 for labor
Old 10-05-2010, 01:18 PM
300whpej's Avatar
im assuming this is a hx/vx/cx (whichever comes with the wideband) for the o2 sensor to cost that much.
Old 10-05-2010, 02:13 PM
Whydid's Avatar
HX, correct. Those prices you guys are saying are for the normal O2 sensors. HXs have wideband ones, much more expensive. I sourced the sensor myself for about $380, which is still very expensive.
Old 10-05-2010, 02:20 PM
Pothole987's Avatar
did you perhaps call the dealer for a price? i got one for 150.00, while napa and carquest quoted me 386.00. but this was a regular o2 4 wire sensor.
Old 10-05-2010, 02:26 PM
kevinm1981's Avatar
go with the single cam like you said your not worried about hp, dont spend extra on going b20.
Old 10-05-2010, 03:14 PM
buy a y8, more practical
Old 10-05-2010, 04:13 PM
kevinm1981's Avatar
or d15b, better gas mileage and same power.
Old 10-05-2010, 06:20 PM
Whydid's Avatar
This is a JDM only motor, correct? Will I be able to keep OBDII?
Old 10-06-2010, 12:29 PM
Jimster480's Avatar
Factory stock.
There is no point in swapping the motor for a O2 Sensor. And there is no labor on a O2 sensor. It is a crescent wrench and about 3 minutes. Thats it. Its going to cost you alot more than $500 for a swap especially if you are paying a shop to swap the motor.
oldz6
26
10-22-2010 09:51 AM
TeamRPM_ZC
04-27-2008 12:17 PM
JDean6pac
13
02-22-2007 07:55 AM
burnett999
21
08-23-2002 09:25 AM
Quick Reply: Cheapest possible practical swap for an EJ7?
