Cheap tires
Cheap tires
Anyone know of a webswite that has really cheap tires?
Another question, what size tire would go on a 16inchx7inch wheel?
Re: (hon da top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">Anyone one know what size tire would go on a 16x7?</TD></TR></TABLE>
https://honda-tech.com/zerothread/1188922
215/45/16, 205/45/16, 225/45/16, 205/50/16
i'd go with the 2nd one
Re: (hon da top)
that depends on the model/year of your car and the size tire it came with originally.
92-95 civics and 96-00 hatches should use 205/40/16 as it is the closest size to the original outer diameter. 96-00 coupes/sedans and integras should use 205/45/16 or 215/45/16 as this is the closest to their original outer tire diameter, preserving the accuracy of the speedometer and odometer, as well as maintaining the same gearing/acceleration.
Re: (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 »</TD></TR><TR><TD CLASS="quote">
92-95 civics and 96-00 hatches should use 205/40/16 as it is the closest size to the original outer diameter. 96-00 coupes/sedans and integras should use 205/45/16 or 215/45/16 as this is the closest to their original outer tire diameter, preserving the accuracy of the speedometer and odometer, as well as maintaining the same gearing/acceleration.</TD></TR></TABLE>
I have a 99 hatch and the stock tire size is 185/65/14. 205/45/16 would be the closest to stock for my year hatch, not 205/40/16.
Re: (EK k kay)
my bad, i was under the impression the ek hatches came with smaller, 185/60/14 or so
but if that is not the case then 205/45/16 is a much better size. 215/45/16 is actually closer to the original diameter but its an uncommon size and most stuff is more expensive in that size. the new azenis come in 215/45/16 though
