cheap HP
cheap HP
any ideas? maybe high comp pistons, and a cam (d-series non vtec 1.6 on the 99) i just want around 160 at most even if i do have to go vtec, though i dont want to at this time....any suggestions guys?
Re: cheap HP (stock_honda_coupe)
there's no such thing as cheap hp, unless you want 3 or 4. But other than that......................<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">Turbo is the chepest way to get power. Your internals can handle 160 easy.</TD></TR></TABLE>
Re: cheap HP (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">You cant put "cheap" and "horsepower" in the same sentence. Thier oxymorons.</TD></TR></TABLE>
Yeah you can, it's called a V8 build.
They're just not exactly what I'd like to call "economical."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">A Bisimoto cam and high compression pistons are a great choice, but in the grand scheme of things, they won't be too cheap.</TD></TR></TABLE>
And there's no use going above a stage I cam unless you do have the high comp pistons as it'll probably create cam overlay and without high comp pistons to support them your compression will drop and you'll be owned.
As others have said, your best bet is turbo on stock internals.
Re: cheap HP (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">And there's no use going above a stage I cam unless you do have the high comp pistons as it'll probably create cam overlay and without high comp pistons to support them your compression will drop and you'll be owned.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">As others have said, your best bet is turbo on stock internals.</TD></TR></TABLE>
I think that's an excellent choice too.
Re: (sil04ver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sil04ver »</TD></TR><TR><TD CLASS="quote">Turbo on stock internals sounds good for cheap HP. You can put together a decent kit for a pretty good price hey?</TD></TR></TABLE>
Yeah, using name brand parts you can throw one together for a D series for around 1500 (tuned).
http://www.d-series.org
http://www.turboD16.com
Read 'em, use 'em, love 'em.
Re: cheap HP (jonnyboo)
there is no cheap HP buy spry is fun until the bottle runs out but is is cheaper then a turbo kit unless you use it all the time and are always filling the bottle
Re: cheap HP (Lscivic1999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lscivic1999 »</TD></TR><TR><TD CLASS="quote">swap a B16 or Gsr plus full bolt-ons, All-set..</TD></TR></TABLE>
that's not what i call cheap
Re: (fireman mike2288)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireman mike2288 »</TD></TR><TR><TD CLASS="quote">u could always put a 50 or 75 shot of wet nos on ur car and hope it holds ^_^ lol</TD></TR></TABLE>
It'll hold fine if you do it right. I wouldn't go much over 75 on stock D internals though.
Nitrous is BY FAR the cheapest way to get the MOST HP out of your car. Only downside is as you probably figured out it's "temporary" - not "full time" power.
EDIT:
Ah ****, somebody's gonna say it, might as well be me...
Don't go much over 75 on stock ints, if you use a 100 shot you'll be lucky if you don't blow the welds on the intake...
EDIT:
Re: (Syndacate)
EDIT:
Don't go much over 75 on stock ints, if you use a 100 shot you'll be lucky if you don't blow the welds on the intake...</TD></TR></TABLE>
No!!!!!! not the welds on the intake. LOL!!!
EDIT:
Re: cheap HP (Boost_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V »</TD></TR><TR><TD CLASS="quote">
that's not what i call cheap</TD></TR></TABLE>
well if he serious looks for parts, Craigslist,ebay,marketplace ar any other classified he can get somthing done easily, or maybe an Ls ive seen Ls longblock for as low as 300$..
if you hard he can cllect parts and get it done..
crvsam
06-22-2008 10:29 AM
98exturd
18
08-27-2007 11:34 PM
