changing transmission fluid help
1 Post
i just got done installing new axles into my 95' civic DX. the motor is stock, but when i installed the new axles, some tranny fuild got out, and my uncle told me i need to add more in...but i can't find where it is, so i can put more in! can someone tell me where it's located, so i can fill it??
fill plug is on the side of the tranny near the driveshaft try this thread:
https://honda-tech.com/zerothread?id=644492
mista bone posted a pic of where it is....
next time try a search tho..
yep thats the one in the link i posted, some people use the speed sensor hole but if you have a funnel with a flexible hose it is dead easy to fill it using the fill hole, you'll need to use it anyway as you need to top it up until it comes out..
Re: (goodbyegti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodbyegti »</TD></TR><TR><TD CLASS="quote">yep thats the one in the link i posted, some people use the speed sensor hole but if you have a funnel with a flexible hose it is dead easy to fill it using the fill hole, you'll need to use it anyway as you need to top it up until it comes out..</TD></TR></TABLE>
yep the easiest way is threw the VSS and use a flex hose to fill untill the MTF spills out the filler hole hope this helps.
Re: (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote">I changed my tranny fluid a while ago in my Si d16z
I only got 2 quarts out and out 2 quarts in. Is there thats supposed to come out?
Sorry to butt in this post </TD></TR></TABLE>
two quarts is all you need.
D Tranny Guru
Re: (Slammed Si)
thank BDC for the pic, and me for hosting the pic.
You know your getting to be a good teacher when students answer the questions for you.
THX!!!!!
THX!!!!!
Re: (kr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kr »</TD></TR><TR><TD CLASS="quote">
yep the easiest way is threw the VSS and use a flex hose to fill untill the MTF spills out the filler hole hope this helps.</TD></TR></TABLE>
search FAQ, archived and/or recent content and looks for b18c5-eh2's post "axle tutorial" ........ pics and full description of how to fill it from the top.......
Re: (Ninety2SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety2SiR »</TD></TR><TR><TD CLASS="quote">What type of oil (weight) should be used?</TD></TR></TABLE>
Honda MTF, GM Synchromesh......... motor oil in tranny
Re: (Kikomon)
motor oil is good if you are broke and have nothing better laying around.
like me </TD></TR></TABLE>
Honda MTF is not that expensive at all man. I think I payed like 4 bucks a quart or something.
Re: (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv »</TD></TR><TR><TD CLASS="quote">
two quarts is all you need.</TD></TR></TABLE>
i thought you needed three quarts of MTF..
Re: changing transmission fluid help (b00st)
if you have automatic... get automatic tranny fluid... if you have a stick...get manual fluid...otherwise...it will be kinda fucked up...
Re: (Ninety2SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety2SiR »</TD></TR><TR><TD CLASS="quote">I just went to my deal and they told me to use just regular motor oil, 10-40 I believe.
What is MTF, does the dealer sell it?</TD></TR></TABLE>
Re: (sleeperciv)
my service manual says 1.8 for tranny oil change. 1.9 for overhaul. but i'm just being picky, 2 qts is fine. if anything, if fluid is coming back out of the fill hole.... then the tranny level is topped off.
Andrew14
21
06-28-2010 01:12 PM
