Changing Tail Lights
Re: Changing Tail Lights (marshun)
its direct replacement but i would recomend not metioning that on this board
EVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Unceasing Measure
Re: Changing Tail Lights (offthewall2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by offthewall2005 »</TD></TR><TR><TD CLASS="quote">I purchased some Altezzas and was wondering if anyone has a guide or some tips on how to put these in myself, I have a 03 Civic Coupe.
Thanks</TD></TR></TABLE>
Pop your trunk, find the two screws on the side of the tail lights that are flush with the rear deack surface. You'll probably have to pop off a panel on the interior of your trunk to get to the little 10mm nuts that hold the tail lights on from the inside, but you'll find it. Be careful not to drop any of the hardware, because it will manage to rattle around like a ************ on crack when you fail to find it.
Enjoy your altezzas. Thanks for making your car look worse so mine looks better .
Re: Changing Tail Lights (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Enjoy your altezzas. Thanks for making your car look worse so mine looks better .</TD></TR></TABLE>
hahahahaha!
hahahahaha!
i have a great idea........i could pretend you never metioned that and we will both go on our merry way!!!!
PS- i'm not joking either!!
Re: Changing Tail Lights (FlamencoEsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlamencoEsi »</TD></TR><TR><TD CLASS="quote">3 steps:
1) get a firm grasp on the box
2) fully extend your right arm
3) heave the box into the garbage!</TD></TR></TABLE>
that is awesome
But yeah dude they install just like any other tailight. Also check to make sure they are properly sealed due to the fact that they will condensate and look even shittier. if your gonna do something do it right.
that is awesome
Re: (offthewall2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by offthewall2005 »</TD></TR><TR><TD CLASS="quote">only reason i had to buy them was because someone smashed my stock ones and these were the cheaper solution</TD></TR></TABLE>
thats what they all say!!!!!!!
Re: (USDMDC2)
Pss...
Here's how I installed my altezza,...first thing's first....
1. open the box and removed the altezza taillights from the nicely packed box!!
2. pop your trunk or hatch open!!
3. place the Altezza taillights behind the two rear wheels....then...
4. go inside your car and start the motor!!
5. put the gear on Reverse!! or (R) the hit the gas pedal all the way!! Notes: by doing this your vehicle will sudden jump over the the altezza and it will magically bolt on the rear!!
5. Done!! Congrats yourself because the crowd will be gather around by your car, when you go to pepboy!!
Oh!! and dont forget when I said it will magically bolts on your rear, there are chances it may end up bolting on to the two rear wheels!! Enjoy your new atezza taillights!!
Modified by HATCHingMN at 11:46 PM 12/9/2003
Re: (95cxhatch)
Here is the quick and easy installation of the Altezza tailight:
1. Remove cracked tailight
2. Remove Altezzas from the box.
3. Throw them violently onto the ground. Use those muscles!
4. Kick them around a bit, it gets the circuits working better.
5. Douse them with a healthy bit of lighter fluid.
6. Light them on fire.
7. Pee on them.
8. Repeat steps 3-7 until the ground surrounding the lights are nothing but smoldering plastic, ash, and pee.
9. Punch yourself in the face for buying them.
10. Go to Honda dealership, or local junkyard to get OEM replacements.
11.Never purchase anything that has the title "Euro" or "Altezza" or "APC" in it ever again. Good day.
7. Pee on them.
Unceasing Measure
Insurance didn't cover your new car against vandalism? Lies.
Re: (EggRolla)
I will be doing this when i can afford stock ones to take the place of my altezzas. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EggRolla »</TD></TR><TR><TD CLASS="quote">Here is the quick and easy installation of the Altezza tailight:
7. Pee on them.
11.Never purchase anything that has the title "Euro" or "Altezza" or "APC" in it ever again. Good day.</TD></TR></TABLE>
7. Pee on them.
MPF_supra
04-24-2006 01:14 PM
