Changing rear wheel studs
I've changed the fronts using this DIY:
https://honda-tech.com/zerothread?id=907985
I need to do the rear's. I took the rear drum off, and it looked like I needed to pull the piece out like I did in the front using an axle puller and slide hammer.
I didn't go ahead and do that as I wasn't sure.
So could anyone confirm that I need to do that? Or possibly point me in the direction of a DIY or just give me some help.
Re: Changing rear wheel studs (thw_goalie)
no just hit it out, there is nothing to remove on a drum. there is enough space behind the plat for you to fit. if not you could shave some of the studs head to get extra clearance.
Re: Changing rear wheel studs (Mr.EM1_EK)
I'm going to be installing extended studs, so I don't think I'll be able to get them in once I get the old ones out.
What do I need to do?
BlueShadow
10
10-27-2004 12:08 PM
Soulless
11-17-2003 12:26 AM
