changing my oil pan gasket help!!!!!!!!!!!
Old 10-09-2009, 08:36 AM
zoopreme's Avatar
Default changing my oil pan gasket help!!!!!!!!!!!
i have a 1996 gsr in my civic and is leaking oil in my oil pan gasket. and i was wondering what do i need to actually do to perform the service like any special kind of hondabond seal etc new nuts or bolt etc. and i will also need the torque spec and i need the diagram of what bolt to tighten 1st to last. sorry for the misspelled and weird sentence in a rush to go to work thanks in advance neeed to get this done asap
Old 10-09-2009, 08:38 AM
roycivic92's Avatar
Default Re: changing my oil pan gasket help!!!!!!!!!!!
just clean the pan and block with oem gasket and then cross torque to specs
Old 10-09-2009, 08:40 AM
zoopreme's Avatar
yeah i tryed that but never a temped of taking it out and tamper with the gasket just clean it very good and still smokes up when i drive
Old 10-09-2009, 08:45 AM
roycivic92's Avatar
is the pan damaged it could be the rear main seal too
Old 10-09-2009, 08:55 AM
zoopreme's Avatar
yeah i have to check is comin mostly from the driverside no damage on the oil pan
Old 10-09-2009, 09:00 AM
roycivic92's Avatar
the main seal is near the pass side
Old 10-09-2009, 09:04 AM
zoopreme's Avatar
have to check when i get to work today. Is that a different piece then the oil pan gasket
Old 10-09-2009, 09:08 AM
roycivic92's Avatar
its where the crank and the flywheel meetinside the tranny casing
Old 10-09-2009, 07:11 PM
zoopreme's Avatar
yeah is getting worst it is leakin from the oil pan and allot at the crankz goes
Old 10-09-2009, 07:28 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Could be the front main seal also. Underneath the timing belt.
Oil leaks suck to find. I just fixed my rear main seal a few weeks ago. You have to be extra careful at replacing it.
The pan should have sealant put on it. Then the gasket lays over it. Put sealant on the bolt threads also. The torque is around 10lb/ft, IIRC.
Old 10-09-2009, 11:39 PM
thumper64's Avatar
Depending what type of gasket you get, you may not have to use a ton of sealant. I prefer Fel Pro gaskets because you usually either don't need much or any extra sealant.
Old 10-10-2009, 05:31 PM
B serious's Avatar
I used a Fel Pro on my oil pan. So far so good, but it's only been a month or so. So we'll see. Seemed to be a decent gasket.
Old 10-10-2009, 07:09 PM
zoopreme's Avatar
where could you buy that the fel pro brand or should i just get oem gasket
Old 10-10-2009, 10:48 PM
boxeocampeon's Avatar
i would get it done by a pro those things are a bitch to change
Old 10-11-2009, 12:40 AM
B serious's Avatar
I got the fel pro one at Autozone for $18 because I needed it right away.
You can get the OEM gasket for around $20 at www.bernardiparts.com
I'd go OEM if you're not in a hurry.
B serious's Avatar
The pan gasket? It's easy as hell.
Old 10-11-2009, 02:11 AM
MySelfAffliction's Avatar
Ha exactly what i was thinking.
_kiid
03-02-2010 05:15 PM
StreetRacinThug
12-21-2006 08:44 AM
deconstruct
06-18-2004 01:00 PM
IntegraB18A
12-20-2003 08:18 PM
AK94GSR
06-24-2003 01:24 PM
Quick Reply: changing my oil pan gasket help!!!!!!!!!!!
