changing crank?
changing crank?
i am changing out the crank in my ls/vtec setup and was wondering if i should use the main caps from my engine block or the main caps from the donner block? can someone help me with this?
Re: changing crank? (93slmdcvcsi)
Use the ones from your current block. If you use the ones from the new crank's block the crank will seize. Just make sure you get the new crank micro polished.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93slmdcvcsi »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Not the answer your looking for?
