changing b16 axels
changing b16 axels
So i noticed the left side looks like it has a dust shield right against the tranny, and the right side is like the regular d series axel, I only need to change the left side, any ideas guys? Not sure how to just remove the left side by itself without damaging the dust cover.
Lol, try removing the dust cover ? It doesn't really matter man, just get that axle out, get the new one in. dust cover.. lol first time i hear this :X
Seagull Management
Re: changing b16 axels (hondazccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondazccivic »</TD></TR><TR><TD CLASS="quote">So i noticed the left side looks like it has a dust shield right against the tranny</TD></TR></TABLE>
You mean the inspection plate for the flywheel? You don't need to touch that.
Re: changing b16 axels (94EG8)
so i'm trying to pry the axel from the intermediate shaft, is there a recommended way to do this, usually on d-series 2 seconds and there out of the tranny, never done bseries not sure how wel it's in the intermediate shaft, and the way it is i can't get leverage from the top, it's on the left side (drive side), let me know guys, sounds stupid i know, but help me out, lol. Thanks.
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondazccivic »</TD></TR><TR><TD CLASS="quote">so i'm trying to pry the axel from the intermediate shaft, is there a recommended way to do this, usually on d-series 2 seconds and there out of the tranny, never done bseries not sure how wel it's in the intermediate shaft, and the way it is i can't get leverage from the top, it's on the left side (drive side), let me know guys, sounds stupid i know, but help me out, lol. Thanks.</TD></TR></TABLE>
Yeah, it can be a PITA. I usually use a short prybar or large flat head screwdriver to pry the two appart. Worse case senario, remove the 3 14mm IM shaft bearing support bolts and pull it out of the tranny. Now you can pry the two apart on a bench. A vice is your friend in this case.
I always pull out the intermediate shaft along with the axle and separate them off the car. It might take a few minutes longer, but it's always seemed easier to me.
hey man do not worry about that shield. just pry that axle out of the intermediate shaft and slide the new one in. you wont harm the plate.
Resident Gearhead
Re: (hondazccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondazccivic »</TD></TR><TR><TD CLASS="quote">ok, so what about the intermediate shaft guys? Do they go as often as the axels? Let me know.</TD></TR></TABLE>
No, but everything wears out eventually.
Mine had 160k on it when I installed it 6 years ago, no problems (I'm not saying this is typical though).
Re: (mcvtec)
Anybody able to tell me how you know if your intermediate shaft is gone? Might aswell check it out when i goto change the axel, had to put the old one back on, as I was given the wrong axel to change out, not a good day, lol.
BONGFIRE420
24
10-06-2007 12:10 PM
NINJASPY
09-19-2003 02:57 PM
