Changed Battery....Now check engine comes is on
Old 12-08-2003, 07:36 AM
EM1SiR's Avatar
Default Changed Battery....Now check engine light is on
just as the topic says. i just changed my battery yesterday, now the check engine light is on. does anyone have any idea why it is on and solution to the problems. thanks...
-joe
Old 12-08-2003, 07:45 AM
be professional
Targa250R's Avatar
Default Re: Changed Battery....Now check engine light is on (LiLJoEPTR21)
What code is it throwing?
Old 12-08-2003, 07:46 AM
NonovUrbizniz's Avatar
what year what model?
It could be that you crossed the lines quickly (although generally you'll blow the main fuse if you do that)...
My brother's odyssey did the same thing (tripped cel) when I jumped his car.
Old 12-08-2003, 07:50 AM
EM1SiR's Avatar
hi. i don't really know what code it's throwing out. the car is a 2000 Civic Si (EM1). let me know what is wrong and what i could do about it. thanks again...
-joe
Old 12-08-2003, 07:53 AM
be professional
Targa250R's Avatar
Default Re: (LiLJoEPTR21)
Check here to learn how to pull a CEL code.
Old 12-08-2003, 08:31 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLJoEPTR21 &raquo;</TD></TR><TR><TD CLASS="quote">hi. i don't really know what code it's throwing out. the car is a 2000 Civic Si (EM1). let me know what is wrong and what i could do about it. thanks again...
-joe</TD></TR></TABLE>
then pull the code dude we can't help you unless you tell us what code its throwing.
Old 12-08-2003, 08:34 AM
Rob!'s Avatar
sure ill just pull it outa my *** and tell you how to fix something that u dont explain what is wrong with it. ********. and to help you...use the directions to pull the cel and then tell us what it is and we will give u a solution to ur problem...but we dont have magical asses to just do anything.
rob
Old 12-08-2003, 10:06 AM
93sol's Avatar
unplug the o2 sensor and plug it back in and see if it goes off
Old 12-08-2003, 10:10 AM
Nextelbuddy's Avatar
Default Re: Changed Battery....Now check engine light is on (93sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sol &raquo;</TD></TR><TR><TD CLASS="quote">unplug the o2 sensor and plug it back in and see if it goes off</TD></TR></TABLE>
how the hell will that help.
Old 12-08-2003, 11:47 AM
EM1SiR's Avatar
Default Re: Changed Battery....Now check engine light is on (nextelbuddy)
hi. sorry for not giving you codes. i'm goin to do that after work. but there was no need to be rude. i'll admit i don't know as much as most of you guys do. it just came on when i changed my battery and i drove for a day. i was just wondering if anyone else had the problem. also, sorry for asking solutions without giving codes. thanks again for all your suggestions...
-joe
Old 12-08-2003, 12:37 PM
Rob!'s Avatar
hey no problem buddy...i was just lettin yah know we need ur help to help you out.
Old 12-08-2003, 12:40 PM
scratchy's Avatar
pull the ecu fuse under the hood for about 15min and it should reset the ecu and the code
Roman00
10-08-2018 07:50 AM
chill841
07-30-2014 06:39 AM
Pabs626
07-02-2008 09:06 AM
211811518
10
09-09-2006 12:57 PM
Siguy00
03-12-2005 01:07 PM
Quick Reply: Changed Battery....Now check engine comes is on
