CFH Suggestions
Old 12-09-2003, 07:49 PM
1strdko's Avatar
Default CFH Suggestions
I have a low quality CFH and want a grade A CFH. I have seen the the DG, Fiber Images, and Wings West models but want to know which is the best quality and is also lightweight? Please suggest a CFH and if you have pictures that would be great!
Old 12-09-2003, 07:58 PM
2000blackgsr's Avatar
Default Re: CFH Suggestions (1strdko)
From what I've read Fiber Images is a good hood, also might want to check out the JDMshit c/f hood.
Vis vs Fiber Images
https://honda-tech.com/zerothread?id=694873
You might want to search also.
Old 12-09-2003, 08:04 PM
HATCHingMN's Avatar
JDMshit is the **** only $379 shipped, quality is good close to perfect!!
VIS=perfect but costly!!
Old 12-10-2003, 06:58 AM
1strdko's Avatar
Default Re: CFH Suggestions (HATCHingMN)
Any pictures? Does anyone know the build quality on VIS and thier front end CF lips?
Old 12-10-2003, 07:21 AM
CharmCity's Avatar
I have a VIS.. very happy with it.. as for the construction, I got hit head on by a drunk driver, totalled my car, one fender was trashed, both headlights busted, the radiator core support was pushed into my turbo, the latch was ripped off the hood, and the hood was knocked back. Just to show the quality of the hood, this is a picture of the car after the accident. With the same hood that was on the car. Granted there are stress marks (can't really see them in the picture because of the angle) and I had to use hood pins because the latch was ripped out of the hood. The bumper that is on the car is a really bad one, but it bolts up until spring when I get a new bumper/hood/. That is why there are gaps in the bumper area. I was VERY impressed with how the hood held up in the accident.
Hood is a little off because of accident, but that can easliy be fixed by messing with the brackets it bolts too..
one more..
Old 12-10-2003, 07:27 AM
MY_EL_1's Avatar
Default Re: CFH Suggestions (CharmCity)
My VIS is a perfect fit
Old 12-10-2003, 12:49 PM
1strdko's Avatar
Default Re: CFH Suggestions (MY_EL_1)
Wow those are nice but how the finish under the hood?
Old 12-10-2003, 01:02 PM
scratchy's Avatar
vis makes a very clean hood but its a little pricey but its worth the money
Old 12-10-2003, 01:11 PM
corgiat's Avatar
well, if u want lightweight Fiber Images is the way to go, and i've heard they're very nice hoods, and they have the unbreakable thing going on, haven't seen many VIS hoods, but like everyone else says, i've heard they're good quality, but a bit pricey
Old 12-10-2003, 02:42 PM
2lua's Avatar
Vis hood and b series swap, you have to cut some under brace cause it will hit the radiator support and rub the right side valve cover where the timing belt at. other brand i dont know.
Old 12-10-2003, 04:44 PM
zer0.'s Avatar
i have a fiber images hood...bot happy w/ the fittment....it seems to rise up too much. can't beat the JDMshit hoods though!
Old 12-10-2003, 05:05 PM
oneslodx's Avatar
VIS makes a very good product. fits near perfect. smooth edges. nice tight weave. great quality. the underside of mine is also cf supports
Old 12-10-2003, 05:08 PM
boostsohfast's Avatar
Default Re: (zer0_2_6ixty)
I have fiber images. Fitment and weave is great but most importantly it is very light so it serves its function.
Old 12-11-2003, 03:50 AM
CharmCity's Avatar
Default Re: (oneslodx)
Oh, if you get a VIS hood.. Don't get the one with Carbon supports on the underside. It is just nicer looking when you pop the hood, but heavier then the regular one.
Old 12-11-2003, 04:06 AM
Charlie Moua's Avatar
jdmshit gets my vote for great price and product! very nice.
if you can afford to spend more get vis or fiberimages, but with newman and jdmshite CF hoods/lips you won't be disapointed at all
Old 12-11-2003, 04:13 AM
93egsi's Avatar
Default Re: CFH Suggestions (Charlie Moua)
my friend has a fiber images hood on his SI......good quality and good fitment .....VIS is def. the way to go, but it is pricey......
SlowEJ8
11
06-06-2009 10:02 PM
justBLZE
13
05-27-2004 06:41 PM
KillerBee18
24
12-07-2003 09:06 AM
R0902
09-14-2002 11:20 PM
CRXBart
17
10-08-2001 01:23 PM
Quick Reply: CFH Suggestions
