cel VTEC pressure valve !!!
when i go to like 6000 rpm the check eingine light come on with code # 22 !!what can it be?I already cleaned it !can it be bad?
Re: cel VTEC pressure valve !!! (Metallivayne)
i just put a b16 block with b17 head and when i had my b17 long block it work fine but now it does not work!!
Re: cel VTEC pressure valve !!! (chuisek9)
i just got the same code on my stock 93 del sol with a d16. i even changed the vtec oil unit, and still have the same code. any help
Re: cel VTEC pressure valve !!! (craig88crx)
if you have wired the Vtec solenoid and the Vtec oil pressure unit, i would look at the wiring.
i had the same issue. the only thing i did was switch the pressure units + wire and the vtec solenoids single wire
hope this helps....
hope this helps....
sevenfc
36
12-28-2022 05:01 AM
VTC_CiViC
11-17-2004 09:05 PM
