CEL & Header Crack
CEL & Header Crack
-So I bought a '97 Hatch for a B16 setup I wanna do.
-It has CEL #41 which is "Primary Oxygen Sensor Heater"
-I buy a Denso O2 sensor and when I was going to put it on I seen this:
I seen someone with the exact same problem with the exact same CEL but I cant find the thread anymore. Should I put in the sensor and not worry about the header since this engine wont be in here for more than a few months?(3-6months tops).
The thing is I need that CEL gone because I need to register it since the tags expired a few days ago and now I need to smog it.
the crack looks pretty bad if air is getting into your manifold from the outside then the o2 sensor will tell the ecu to keep on dumping more fuel into the engine thus killing the new o2 and probably your cat
Re: CEL & Header Crack (EM2RCR)
That is very common on these......Ya mite be able to have it welded...if not they sell an aftermarket replacement on ebay pretty cheap
* B A N N E D *
Re: CEL & Header Crack (cimo463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 »</TD></TR><TR><TD CLASS="quote">That is very common on these......Ya mite be able to have it welded...if not they sell an aftermarket replacement on ebay pretty cheap</TD></TR></TABLE>
Dont you mean Buy????
Your saying you didnt hear an exhaust leak with a huge crack in the mani like that? I dont know man, Im a tech for honda and also have a license for NYS Inspections and i would fail the crap out of that..California, from what i hear is more strict than NY when it comes to emissions so good luck. If i were you i would hit up the local junkyards..
Re: CEL & Header Crack (jdeemseerx)
ok so its best if i just get a new stock header and THEN replace the new o2 sensor then get it smogged? I do live in California I just hope it passes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2RCR »</TD></TR><TR><TD CLASS="quote">ok so its best if i just get a new stock header and THEN replace the new o2 sensor then get it smogged? I do live in California I just hope it passes </TD></TR></TABLE>
basically what you have to do weldin cat iron isnt easy so it will cost
Re: CEL & Header Crack (ReactioN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReactioN »</TD></TR><TR><TD CLASS="quote">
Dont you mean Buy????</TD></TR></TABLE>
No read what i said again.......they (as in the people who sell things on ebay) SELL aftermarket replacements pretty cheap
Re: CEL & Header Crack (95delsolz6)
yup i jus seen some on craigslist for 35 bucks im bout to pick em up this tuesday. does anyone know where theres a good DIY for changing the header? the one under the FAQS has no pictures..i need pictures
Re: CEL & Header Crack (MonkeyMagic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic »</TD></TR><TR><TD CLASS="quote">you bought the car for a swap... just ignore it until you swap
I cant I have to get it smogged and registered my tags expired in April. Ima jus get a new header and o2 sensor on there and see if it passes smog
if you cant figure out how to replace an exhaust manifold/cat i would hate to see whats going to happen when you do the swap
- BSeRiouS -
Honda S2000
09-06-2006 10:09 PM
jumai182
18
08-09-2006 06:59 PM
