Cel code no.1 came on when cruising with AC
Swaggylicious
So I've been throwing codes 1 and 43 which is for the o2 sensor.I changed it out yesterday and cruised around town for around 100 miles and no codes,though I never had the ac on.this morning driving to school with the ac on,cel no.1 came on
What psi should my fpr be at? It's currently at 56 with the vac hose on.
It's a b16a2 with I/h/e and itr cams on stock ecu
Thanks everyone
Thanks everyone
Swaggylicious
Re: Cel code no.1 came on when cruising with AC
It came off my buddys Si,so I'm assuming oem
I'm wondering if it's running rich because of the increased psi from the fpr
Code 43 -- not code 1 -- could be caused by a fuel pressure problem.
High fuel pressure would certainly cause an engine to run rich. What was the pressure when the FPR vacuum hose was disconnected?
Swaggylicious
I don't think so?the fpr was adjusted because I rookie to the dyno with a different ecu and it needed more fuel.it adjusted so I don't think it's done for
95hatchfire
01-12-2005 10:52 AM
