cel code 22 vtec pressure switch HELP!!
Re: cel code 22 vtec pressure switch HELP!! (esoterEK..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esoterEK.. »</TD></TR><TR><TD CLASS="quote">did a search and those threads aren't helping..
oil's good.
ground wire's good.
switched out pressure solenoid already.
what else could be the problem?
the plug's bad?
or the vtps wire's bad? <--it's cut and connected at 2 locations.
like this [plug----+-------+-----ecu]
could that be the problem?
vtec kicks for like 10 secs then dies out and the code comes on..
after i turn ignition off and start car again..it does the same thing. vtec on and off.
seems like a wire problem but just wanna ask first..
help out if u can..
thanks!!!!
setup is 96 hatch obdIIa running '00 b18c1 stock.. '97 gsr ecu
Modified by esoterEK.. at 4:47 PM 2/6/2006</TD></TR></TABLE>
oil's good.
ground wire's good.
the plug's bad?
help out if u can..
thanks!!!!
Do you have a VAFC?
Sounds like a wire problem to me.
There is a VTEC troubleshooting flow chart in the Helms
Re: cel code 22 vtec pressure switch HELP!! (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood »</TD></TR><TR><TD CLASS="quote">Do you have a VAFC?
There is a VTEC troubleshooting flow chart in the Helms </TD></TR></TABLE>
yea i did..but took it out..
it's probably the splicing of my wires and reconnecting it...
it's probably the splicing of my wires and reconnecting it... </TD></TR></TABLE>
That would be a good guess. When I had moved the wire harness where i had my VAFC hooked up after installing a chipped ecu it gave the same code. Turned out the wires were garbled.
PnkRokCountryboy
09-02-2007 02:21 PM
ViXoN Hatch94
11-28-2005 01:40 AM
