CEL came on, speedometer not working
I have an '00 Si. I reversed up a small driveway and the CEL came on and now my speedo won't move off of 0mph.
Is my speedo electronically controlled, or cable controlled and would it breaking set off a CEL?
Advice is appreciated.
Thanks
Jason
Thanks
Jason
Re: CEL came on, speedometer not working (Hybrid96EK)
Better explain to the noob how to pull a code.
JasinC19, take it to Autozone, they do it for free, or do a search on here"pulling cel codes" to get a thread on this topic. There are several of them.
Re: (JasinC19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasinC19 »</TD></TR><TR><TD CLASS="quote">I have an '00 Si. I reversed up a small driveway and the CEL came on and now my speedo won't move off of 0mph.
Thanks
Jason</TD></TR></TABLE>
It's electronically controlled, not cable controlled. Breaking the VSS (Vehicle speed sensor) would set off a code #17 - the check engine light.
For how to check your codes without a scanner go here:
https://honda-tech.com/zerothread/1901557
If you have a '96+ you can get a more accurate code with an OBD-II scanner (like "system too lean" or "system too rich" opposed to just an OBD-I general "fuel supply system."
Thanks
Draggin99Si
08-18-2003 08:36 AM
ModAddict
02-07-2003 07:06 PM
