CEL # 6, 7,14, 22,23
ok so my dads car was throwing cel # 7, 14, 23.
I know the 23 is for the knock sensor. which is unplugged at the moment.
I just replaced the throttle body and idle air control valve today.
After replacing them im now throwing cel # 6,7,14,22,23.
ive looked at all the underhood grounds. radiator support to valve cover, frame to tranny, thermostat ground, and batt ground. and all the ground box by the headlight.
this is a 93 civic with a jdm b16..was working fine with no check engines. he warped a couple valves from overheating, so he go the head redone and surfaced. during the head swap he broke the knock sensor. Im waiting on a new one to get here.
I dont understand the other cels. Im pretty sure all the sensors are good. Any help is appreciated, THank you
Re: CEL # 6, 7,14, 22,23
i will check for swapped sensors.
its a 2 wire iacv 3 wire tps coming off the loom so i think those are good...
the map sensor is plugged in correct spot..
mite be the air temp sensor since its a jdm manifold i have one sensor left over. i will check
as for vacume leaks. i will look at those.
Technical Hero
take a picture of the engine harness near all the sensor with wire colors to all the sensors for all the codes you have sounds like something is switched
ok so found the problem. i guess my dad spliced a wire onto the thermostat ground that wasnt supposed to be there.
believe it is one of the wires used to splice in vtec.
i still have the 22, for the pressure sensor on the solinoid.
and the 23 for the broken knock of course.
