CEL 22 what do I fix, replace?
Old 04-03-2009, 08:24 PM
egGSR_hi's Avatar
Default CEL 22 what do I fix, replace?
Hi,
Im new here and i drive a Honda civic with a swapped gsr. I just recently got a CEL code #22 thrown and I can't find the solution on fixing it. I checked the wire's & they seem fine. I've also replaced the Oil Pressure Switch with a brand new one from Honda and that didn't help. I already checked the oil and its reading fine. Do I have to buy a whole new Vtec solenoid? I was also told to check the oil pressure how do i do that?
Old 04-03-2009, 08:28 PM
Former User's Avatar
Default Re: CEL 22 what do I fix, replace?
Try cleaning the filter inside the solenoid. It may be clogged.
Old 04-03-2009, 08:31 PM
egGSR_hi's Avatar
thank you for the help its pretty late so I'll try that tomorrow morning. Should i check on anything else that may be the problem? I'll report back on a update to see if it works.
Old 04-03-2009, 08:34 PM
95sloweg's Avatar
if the guy who swapped that motor had to wire the vtec straight to the ecu, you might want to double check to make sure that wire did not come loose. its the wire that goes to D6
Old 04-03-2009, 08:37 PM
egGSR_hi's Avatar
thank you I did not swap it so I check that out too I hope it gets fixed with these solutions because its no fun looking at that bright CEL at night.
Old 04-03-2009, 08:52 PM
Thizzed Out's Avatar
i have this extact problem 2 I just havent had the time to look at it again if you find a way to fix it let me know
Old 04-03-2009, 09:01 PM
egGSR_hi's Avatar
I will do that thizzed_out one more thing i just remembered when Im driving is that the CEL doesnt come on till I go into vtec. I just wanted to let you people know how extactly its giving me a code just incase it can be anything else.
Old 04-03-2009, 09:13 PM
Are any other CEL codes thrown?
Old 04-03-2009, 09:20 PM
egGSR_hi's Avatar
no only "long long short short" which would be cel 22, does this problem usually throw other codes with it? any other solutions to this problem will be great and I'll be trying them out tomorrow. I think this is also my last post of the day since im new and i think im only allowed to post 5 posts per day. Thank you for your feedback RonJ@HT and 95sloweg
Old 04-03-2009, 09:51 PM
I'll check up on this tomorrow
Old 04-04-2009, 02:29 AM
Kyoh's Avatar
I had this problem after i swapped my in my gsr. I ran a straight wire to the ecu and it worked. If it doesn't pop vtak then, try switching solenoids.
Old 04-04-2009, 02:53 AM
egGSR_hi's Avatar
yeah vtakk yo! doesnt engage at all once the code is thrown. I'm going to pull the solenoid and clean it but what exactly kind of cleaning supply do I use to clean it?
Old 04-04-2009, 04:22 PM
egGSR_hi's Avatar
ok I cleaned the solenoid (even though it looked clean) and I checked the wiring again and everything seems to be fine. But its still throwing code 22 at 1st it will only throw it when I hit vtec now its on right at start up.
Things I've done:
Replaced Oil Pressure Switch
Checked Wiring
Cleaned Solenoid
Checked Oil Level
now what to do?
Old 04-04-2009, 05:07 PM
i have cel 22 also
Old 04-04-2009, 05:15 PM
Are you checking the VTEC wiring as instructed in the service manual?
Old 04-04-2009, 05:37 PM
I don't have a manual but I checked everything near/around the solenold they are all pluged good.
Old 04-04-2009, 05:42 PM
I PM'd you. You need to check the VTEC wires with a multimeter. You'll miss many electrical problems if you limit yourself to visual inspections.
Old 04-04-2009, 06:22 PM
awesome Im going to send it to EGgsr to if thats cool. I'll check up on it and report back (no trying to thread jack OP)
Old 04-04-2009, 06:32 PM
Good idea.
Old 04-04-2009, 06:58 PM
joelmatt89's Avatar
Well you definetely need to check the wiring from the plugs to the ecu with a multimeter that is the first step. But there is also another situation which every one seems to have missed is it possible your not getting enough pressure there i would think you may want to change your oil just to be safe. Here is a really good write up on vtec related problem that details some troubleshooting methods. https://honda-tech.com/forums/honda-prelude-4/official-%22why-vtec-doesnt-engage%22-thread-830163/
Old 04-04-2009, 08:42 PM
egGSR_hi's Avatar
the oil is good i changed it maybe like a month ago and I only drive this car maybe 3times aweek so it should still be good. I changed the entire solenoid today (borrowed from a friends gsr) and im still getting the code. Im going to recheck the wiring again to be sure. thanks for sending that info Ron@HT
Joelmatt89 thats alot of helpful information im forsure going to read up on that. I'll get back to you guys and see what goes on.
Old 04-05-2009, 05:14 PM
egGSR_hi's Avatar
I went ahead and checked the wires again with a multimeter since I was told to. It turns out that my blue/black wire for the pressure switch wasn't working properly. I changed the connector and wire and plugged it up. Now it works flawlessly thank you for your help and input everyone.
macDelli
13
02-12-2011 11:28 AM
wrx'n you
11
11-08-2006 07:55 PM
speedhatch
01-24-2006 01:50 PM
sir2chad
03-09-2003 01:45 PM
FusionITR
09-20-2002 12:46 PM
Quick Reply: CEL 22 what do I fix, replace?
