CD player installation problem.
Old 02-24-2008, 09:44 AM
xCivix's Avatar
Default CD player installation problem.
I installed my Cd player last night...i connected the wires..and went to test it to see if there was power...nothing happened, i touched the connected batterie wires with the ignition wires and it turned on...so i left it connected, but everytime i start the car the clock and the cd player reset...??
Modified by xCivix at 11:37 AM 2/24/2008
Modified by xCivix at 11:59 AM 2/24/2008
Old 02-24-2008, 10:06 AM
instrument's Avatar
no, you installed it wrong.
Old 02-24-2008, 10:07 AM
random chaos 85's Avatar
Default Re: CD player installation problem. (xCivix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">no, you installed it wrong.</TD></TR></TABLE>
Old 02-24-2008, 10:12 AM
DC5Chris209's Avatar
You need to connect the redwire to the red wire in the aftermarket stereo harness.
If you were stupid and cut off the OEM harness go look up the wire code for ACC.
Old 02-24-2008, 10:18 AM
xCivix's Avatar
I connected the battery line and the ignition but it doesnt turn on...then i put all 4 of them together and it worked..?
xCivix's Avatar
red and red
yellow and yellow...
Old 02-24-2008, 10:26 AM
Blzdeep's Avatar
hahaha, i shouldnt laugh .... but ..... NM
Old 02-25-2008, 02:54 PM
That is the correct sequence.
Check your fuses.
Old 03-20-2008, 05:07 PM
xCivix's Avatar
Default Re: (DC5Chris209)
I just found out what it is...the battery fuse (yellow wire) is under the hood... i thought it would be under the drivers...ThankS!
si_23
04-10-2011 01:56 PM
madmortar
Audio / Security / Video
05-13-2008 12:23 PM
Lucky-13
03-11-2007 07:55 AM
higgunscrx
06-06-2006 05:04 PM
ineedmoney
06-03-2004 06:28 PM
Quick Reply: CD player installation problem.
