car wont turn over!!! NEED HELP! please
k so i replaced my timing belt and now the belt wont tighten up.....im assuming that the tensioner is bad and i will have to buy a new one. BUT even with it on somewhat loose the car wont even turn over now. i havnt messed with anythin since doin the timing belt does anybody have an idea. oh also its a 93 civic cx with a jdm b16a in it. thanks for the help in advance
Re: car wont turn over!!! NEED HELP! please (93hatcheg)
I recently did a timing belt on my D16Y7 and also did a H23 DOHC prelude timing belt all about 3 weeks ago. I know that on the DOHC there were specific intructions on tightening the belt. You also had to make sure that EVERYTHING was aligned PERFECTLY. Oil pump, balancer shaft, crank pulley, both cam gears, etc. The H23 had 2 belts. My d16y7 was much easier and only used 1 belt.
If I remember correctly I think the instructions mentioned something about loosening the adjusting nut/bolt on the tensioneer, then rotate the engine 3 to 5 teeth (forgot which way) then immediately tighten the adjusting nut on the tensioneer. During this, you need to make sure that NOTHING jumps a tooth which can happen very easilly. Good luck with this. Timing belts can be a PAIN IN THE ***!!!
93hatcheg
08-14-2008 09:19 PM
h22aseemsgood
11-14-2006 06:53 PM
