Car won't turn over
Car won't turn over
Okay, so my friends 93' Del Sol (Stock D16z6) won't turn over.
Had the starter tested and it works fine. We then pulled the clutch switch and we hear the clicking when its pressed (we thought it might be the clutch switch that sends the signal to the starter)
No noise from the starter at all but the fuel pump, stereo, dome lights, ect. turn on just fine. We tested the starter with a multi metor and it is getting power.
We are able to jump start the car and it will run just fine.
Cliff Notes - Starter won't engage - Checked all fuses and grounds.
Any help on this would be great...
Thanks
- Dave
Modified by tweak at 12:45 AM 6/2/2005
Thanks
- Dave
Re: Car won't turn over (tweak)
Does you CEL come on? Do you have that code?
I would suggest you ignition coil, but if you can jump and it keep running then that probalby isn't it. Maybe your Ignition Control Module?
romomatic
06-24-2013 12:57 PM
