Car Won't Start....running out of ideas
Drive a D16Y7. Usually after I drive a good while and turn off the car, it'll turn on easily like normal. But after the times I don't drive the car for hours like over night or just during the day when I don't drive, it'll take forever to crank up. I did a tune-up about a few months ago, new spark plugs, new spark plug wires, ignition coil, and all. I recently change the spark plug wires since I had warranty on them but after I did that the car ran as usual. This problem occurred weeks later.
Battery I have now is few months old but I got the cheap one with 450 cranks. When the ignition is on, everything inside works, doesn't show lack of battery. Haven't tried someone else's battery but I'll give it a try today and see if it cranks easier like that. My car takes about 4 cranks before it'll actually start and it'll only do it after I let go of the clutch with the ignition all the day (it'll struggling pick up on it).
Think it might be the alternator/starter? Anyone know how much they go for and how hard it is to replace one?
Re: Car Won't Start....running out of ideas
Are you saying that currently the starter turns the engine only slowly/weakly versus quickly/strongly like normal? If so, definitely make sure that the specs of the battery match the car with respect to cold cranking amps. Also use some steel wool to clean the battery posts, connectors, and the ground wire attached to the chassis. Then go from there.
Is it hot outside? Car cranks but cuts off? If so, It might be your Main Relay, if its hot outside and inside of the car it will take a couple of tries to get the car to crank up, until it cools off. Thats a sign of the Main Relay going bad. You should pull it out and check for cracks.
The Main Relay is located on the left side on the driver side under the fuse area.
Looks like this
Looks like this
Is it hot outside? Car cranks but cuts off? If so, It might be your Main Relay, if its hot outside and inside of the car it will take a couple of tries to get the car to crank up, until it cools off. That's a sign of the Main Relay going bad. You should pull it out and check for cracks.
Looks like this
Looks like this
But like you said, if it is the Main Relay, how can it go bad with cracks? Also how can I fix if it is going bad or test it to see if it is the problem?
The Main Relay likes to act up only when its hot, not cold. I apologize for not being detailed about the crack. It tends to go bad when the solder itself cracks, not the case of the Main Relay . Ive had this case on both my EG and DC, when its really hot outside and inside the car. I would have to air out my car before I could crank it. If not, it would just crank up and die...and after it cranks up its fine for the whole day.
Easiest way to test it, is to borrow a friends or buy one test it out and return if its not it.
Here is a good link to help you understand the symptoms of the a bad Main Relay.
http://www.tegger.com/hondafaq/mainr...mainrelay.html
when was the last time you changed your fuel filter? If its dirty and clogged it can cause a no start condition. Relays cost a grip so start with the filter dude!
Forgot to mention that after trying to crank those many times, I would pop the hood just too look for anything unplugged perhaps but I did keep smelling fuel, at first thought it was a leak, I haven't changed the fuel filter, don't know if the previous owner has either. (I'm the second owner) where can I find the filter?
Sounds just like the Main Relay problem I use to experience, drove me nuts. I personally think its your Main Relay,especially how you just described it being parked at both your parents house in different climates.
Hope you find your problem, good luck!
Any idea for costs and how hard to install it? Is it only underneath the dash that the relay is? or is there more parts of the relay besides that?
http://cgi.ebay.com/ebaymotors/98-99...Q5fAccessories
I know eBay fails but just a thought if anyone knows any other place that sells new one's LMK, Where did you get yours?
Its $69.99 at Autozone if you have one in FL. Its simple to install, just getting to the bolt can be tricky. And that is the only one located under the drivers dash, on the upper left side and thats the only part you need to replace.
$70 for an OEM or like a duralast brand? According to the link you posted there should be 2 sides which two plugs can go in right? Or just 1 plug plugs into the relay.
I c so the screw holding the relay is a bitch I guess. Well I'll check and test it with my friend's relay as well and see if that is the problem. I'll also check the fuel filter since I don't think anyone has changed that. Thanks everyone for the help!
debogsr
03-25-2008 10:23 PM
civic92si
03-29-2007 08:28 PM
dailydriven91ex
07-20-2004 11:42 AM
