Car won't Start??
Car won't Start??
I have a '94 Integra. I was driving it and the timing belt snapped off. Do I just put a new one on or do I have to open the motor up and check everything? If so, what am I supposed to check and fix? PLEASE HELP???
Re: Car won't Start?? (mantyboi)
yikes...if i were you i'd take the head off and make sure your pistons didnt say hello to valves..if they did you might be needed a new head/top end rebuild...if everything looks good then just replace the tming belt and tensioner...oh and i'd do the water pump while your in there
there are plenty of articles on HT about replacing the timing belt....https://honda-tech.com/zerothread?id=649277
your will be a little more challenging since its a DOHC, make sure you set TDC before installing the belt! good luck hope your motor isnt fubared
modernvisionscc
08-03-2007 08:56 AM
