Car will not stay running after motor got wet (( HELP ))
Old 10-21-2007, 07:13 AM
.Hookedonhatch.'s Avatar
Default Car will not stay running after motor got wet (( HELP ))
My cousin has a 92 hatch with a poor mans type r swap. Car is running off of a p28 with hondata s200b. We swapped out the radiator from an aftermarket to stock and the car was running perfect prior. There was some pressure still in the lines and coolant sprayed all over (but not into the intake). There was water down in cylinder 1 spark chamber. We drieed everything out then i pulled the plugs they are fuel fouled. I replaced them, started the car it runs ok then shuts off. Smells like fuel, What could have caused this.
Things i have tried:
Dried out spark chambers
Pulled and replaced plugs and wires
no moisture in dizzy cap
all injectors are firing (used screwdriver to hear clicking)
reset ecu (several times)
car orignally was missing bad but now runs ok but will stutter once in a while then just shut off randomly. HELP PLEASE
Old 10-21-2007, 12:17 PM
Default Re: Car will not stay running after motor got wet (.Hookedonhatch.)
anyone ????
Old 10-21-2007, 12:24 PM
dc2doi's Avatar
Firing order is it correct?
Old 10-21-2007, 02:01 PM
michael123's Avatar
change the oil bro or check it if u have water bubbles
Old 10-21-2007, 02:06 PM
Default Re: Car will not stay running after motor got wet (michael123)
firing order is correct, the car ran perfect prior to this water/coolant situation
Old 10-21-2007, 03:43 PM
awdgsx96's Avatar
Did you happen to mess with vaccuum lines? Or did coolant maybe get into a wire harness? Check the fuse box and all harness connections
Old 10-21-2007, 06:26 PM
92sihbk's Avatar
Default Re: Car will not stay running after motor got wet (awdgsx96)
make sure your ecu ground is solid. its on the thermostat housing, maybe you hit it by accident
Old 10-22-2007, 01:29 PM
Default Re: Car will not stay running after motor got wet (92sihbk)
anybody else i am running outta ideas. The car is not running smooth at all it sound like it is missing and it will idle for a mins and then stumble and shut off and it smells like fuel bad afterwards ANybody
Old 10-23-2007, 12:35 PM
OMG it'Z McFLY!
markD.'s Avatar
shouldnt have taken out the fresh koyo rad i put in there
check ur fuses under the hood. or check the o2 sensor coming into contact with medal/fouling out
edit: its a p28 with s100b
gworthyunit
11-19-2006 10:28 AM
supracrx
10-29-2006 10:00 PM
jmb92
02-23-2004 05:39 PM
Ass_Clown
11-27-2003 04:29 PM
Quick Reply: Car will not stay running after motor got wet (( HELP ))
