Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: Why won't my Engine Rev Above 4000 RPM?
Guide to diagnose touble and recommended solutions.
Car Will Not Go Past 4,000rpms
#27
Re: Car Will Not Go Past 4,000rpms
well you can try messing with the throttle position sensor, i had a similer concern and it turned out to be the tps, or do you have launch control disabled with the s300 check and see if its on.
#30
Your ECU is running in limp mode. I dunno if you already fixed your problem but this happened to me.
Did you install the ITR motor into a DX Civic? If so, your TPS and MAP sensors are switched around. Extend one of them, and switch them around. Reset your ECU and you should be fine, if that was the problem.
#31
^^^ yea what he said
thats what I was thinking...mine does this same stuff right at 3000 miles when I need an oil change and the oil pressure light flickers, soon as I change the oil everything goes back to normal
I have a code for a bad EGR valve also, but Im assuming its the engine oil pressure going down that send the ecu into limp mode??
#32
My car did the same thing. But as soon as I hooked up a chipped ecu with knock and o2 disabled it ran up to the normal redline.
#33
dont gsr's have the butterflys in the intake? i bet that would do it if those are staying closed.
never messed with a gsr or anything like that, but i could see that doing it...
just an idea
just an idea
#35
#37
Have you checked to see you haven't pulled anything out of your ecu pinout. If something pulls out of your ecu harness it would cause similar problems.
