Car will not crank-95 ex mt
So the other morning I walk out to start my car. And it cranks in slow motion and just stops. It now will not start cranking.
I have checked and replaced several things. I checked the battery voltage-12.7 volts. I replaced the starter (it was about to go anyways). Tested and it's getting power. I jumped the starter from the battery. It just clicks. I checked the starter cut-off relay and use the horn relay to test it. Still just clicks. I jumped the connector for the clutch safety switch as well. Still clicks...checked continuity..good. I checked the ignition switch for continuity via the fsm and it was all good. Ground near the starter seems good. I'm running out of ideas. Did I just get a crap starter? Any ideas would be greatly appreciated. |
Re: Car will not crank-95 ex mt
Take the battery into autozone, napa, etc and have it tested for dead cells. Happened on my 99 Civic a while back, same symtpom just appeared out of nowhere, tested battery and it had 2 bad cells, new battery and trouble free since then.
Ok I'm gonna do that tomorrow. One of my friends just told me the same thing. Thank you
Originally Posted by Project97EX
(Post 49712233)
Oh also I tried jumping it and it didn't work. I forgot to put that
Clean/tighten the battery posts/connectors, the G1 battery ground attached to the chassis, and both ends of the G3 transmission ground.
You guys were right. Battery had dead cells. Thanks a ton!!! I appreciate it!
