Car turns over but won't run
I was driving along yesterday and my car just quit. It will turn over but won't run. Checked the spark plugs, changed the fuel pump and filter. Anyone have any ideas???
1999 civic coupe EX d16y engine
Re: Car turns over but won't run (Mr. Teal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Teal »</TD></TR><TR><TD CLASS="quote">didya check yer fuses der?</TD></TR></TABLE>
I got my car and some of the fuses arent there and i couldnt tell which ones were missing cause the fuse cover was gone so i ordered a new one and it did not come with the graph to tell me what fuses go where. anyone have a link for the fuse diagram?
Re: Car turns over but won't run (MemphisR1-freak)
Try the main relay....when you turn the key to the second on position before cranking...you hear the fuel pump from the back seat? If not..then you're not getting fuel...pump isnt pumping=bad main relay....usually.
Try that....if not..then we can look for other solutions.
same thing happened to my civic, cept i HAD a b18b swap. found out my ecu blew...and so did my motor. damn timing belt.
Re: Car turns over but won't run (screwballz)
my car wouldnt start, although i wasnt driving it at the time like yours. Turned out my dizzy's rotor and cap had MAD oxidation so i wasnt getting any spark. YOu might want to check that out being as you only have to take out 3 screws to check. wont take you more than 5 min to see if thats maybe the problem.
Re: Car turns over but won't run (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I'd check the distributor, ignition coil and ignitor</TD></TR></TABLE>
I checked the distrributor, ignition coil, and ignition before I switched fuel pump and everything. All that is within normal. I also checked the relay and it is working as well. What happened with the timing belt
si90rex
06-24-2007 05:53 PM
white90crxhf
12
08-17-2006 09:16 PM
