Car starting Problems Help Plz
I've been trying to figure what's wrong with my car, and I would just like to get any help please. I've searched, and found nothing has worked for me so far.
Car Spec: 92 Hatch B18b stock and stock ECU. What happened before problem: Was just driving low speed and around 3k rpm only, but suddenly car dies, and won't start, just makes the "chugga chugga" sound. Problem: High idle, low idle will die, won't start: The car starts sometimes, randomly. Most times it cranks but never start. When the car does start, it idles at a stable 2k but abnormal. When I tried to lower the idle using the throttle cable and/or throttle screw technique, the car idles too low and dies or just the idle stays high. What I've done: - Check vaccum lines. all good. - Main Relay using 3 clicks techinque all good. - Battery almost new. good. - Timing belt and Timing seems good, may have to check it again. Don't think it's the timing though, or else car won't ever start right? - Grounds should be good since car starts sometimes. - dizzy good. - new spark plugs and wires. checked for spark using ground techinque. good spark. - did the FITV to lower idle rpm, tightening the white plate with springs. -causes idle to be more stable but still idle high. - cleaned the IACV with carb cleaner. -changed nothing. - fuel pump sounds like it's working. - fuel seeps when i loosened the bolt, so there is fuel coming in. but I don't have fuel pressure regulator to see if there's enough pressure. I really don't know why it randomly starts, and when i set it to idle low it shakes and dies, but when it set to idle a little high, just stays high. I think I did all I could possibly do except throw in the kitchen sink. any help or what I diagnosed wrong would help me greatly. |
Re: Car starting Problems Help Plz (eg6infinite)
free bump.. I have sort of the same prob
