Car starting issue after APEXI DECS Tach installed
Hi,
I got a civic with h22 swap. It was running normal. I was installing APEXI DECS Tach and now the car start and dies. Sometimes it wont start it just keep turning over. I have read the manual for the tach ( red wire to 12v, green goes to back of cluster blue wire, black to ground and yellow to parking light). I wired the sensor for oil pressure too by removing the stock sensor and running new wire for the tach to the new sensor. I have no oil leaks. Do you think guys that there is short somewhere? Or something wrong with the oil sensor installation? Any advice would be appreciated.
Fish Twig
Re: Car starting issue after APEXI DECS Tach installed
Hi,
edit: how did you wire the oil pressure sensor? With the provided harness?
I followed the provided instructions. The tach comes with oil pressure sensor and coolant sensor. There is one single wire goes from the back of the tach to the oil pressure sensor and the other single wire goes to the temp sensor. The other four wire for the tach one for the 12v and one for ground and one for the tach and the last for the parking lights. The tach works no problem and sensors reading are ok but the car sometimes starts and dies immediately or start for a minute and dies
The Same! I just pulled the codes and i am getting code 4. Crank position sensor which makes me think that while installing the tach, the distributor wires got shorted.
omgwtfbbqcrx
05-09-2006 08:17 PM
GsrTurboCRX88
03-20-2006 03:18 PM
