TPS calibration problem
EG Coupe, JDM B16. I just installed a Skunk2 68mm TB and I am trying to get the calibration right for the TPS. OK closed throttle 0.5V, WOT 4.5V. I set the WOT at 4.5 on the dot, let it sit for a few minutes and made sure it stayed there. Now this is where my problem starts. The lowest I can get the voltage for closed throttle to read is .776. Should I compensate for that on the WOT voltage? Or is my TPS sensor bad?
Re: More TPS problems.
You are doing the calibration backwards. First set the closed throttle voltage to 0.5V. Then when you check the WOT voltage, it should be approximately 4.5V.
Re: TPS calibration problem
Holy Cow RonJ havent seen you in years man, I was Frankmoocivic on clubcivic, how are you? I did the exact same thing my tps will not read any lower at closed throttle.
NE Philly, around Frankford and Academy. It's still a funtioning daily, but it gets annoying when I have to pull over to adjust. I just don't know if anything else could be casuing it other than the TPS.
05, 45, backwards, calbration, calibrated, calibration, civic, error, honda, problem, read, right, skunk2, tb, tps
