car died while driving
hey guys, i am new to this forum. i just picked up a 93 civic hatch today and got a great price. being that i got a great price i figured the engine wouldnt last. i tested it out and it was fine for 180k. on the way home it just died. so i let it sit and then it would start up but it would idle funny then turn off. could it be timing. its not a dd its the new project so im ni no rush. thanks
Re: car died while driving (thompsonader)
Have you checked the rotor to see if it is still on the distrubuter shaft. Does it have a reliable spark?
Then check to see if you have fuel pressure.
i messed around with it a little today. would the stereo and the lights work if it was the alternator? it kinda started when i tried while reving the gas but then shut off, without using any gas it dosnt turn over. everytime i try it kinda gets ferther away from starting.
pull your plugs nd check them out, if one is smashed then you have yorself a blown motor. if not might be a distributor problem
Re: car died while driving (fmrprojects)
ok thanks, if blown would i need to replace the entire engine or would the head still be good? if its a distributor problem how would i deal with that?
Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">check your alternator. </TD></TR></TABLE>
My bro's 92 Si had his dying on monday and mine on my Mazda die on tuesday. Hell of a week.
Do you have power (lights, clock, radio)? My car idled funny and died because the alternator is shot. Have a look at it.
Re: (thompsonader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thompsonader »</TD></TR><TR><TD CLASS="quote">yes, the light and radio r working fine. i would love it to just be an alternator.</TD></TR></TABLE>
it is not.....my cluster went out, then my blinkers and then the car just quit, all of which within a couple days. I knew it was coming. If you do not have these symptoms, its something else.
I had a similar problem a while back. Turned out my electronic fuel pump was blowing a fuse over and over due to a wire touching. The fuse blows my fuel pump cuts out car dies. -.- anyway i fixed the wire. but it could be your fuel pump is worn out. just a thought.
