car chokes itself when i hit the gas
Ok first let me start out with my set up LS long block, jdm (LSD) gsr trans, light weight fly wheel stage 3 clutch, skunk 2 intake manifold, and skunk2 throttle body, keep in mind this is a obd1 engine converted obd2A and obd2A p75 ecu alright here is my problem im having i recently just bought this throttle body (68mm) before i installed the tb the car idled and ran fine reved up fine no problems or anything when i had changed out the tb the car idled fine and when i would hit the gas the car would not rev up it would choke and almost stall out in place. if i keep it floored the revs will get REALLY LOW!!! and back fire i changed out the tps thinking it went bad in the change over of tb's i measured the tps voltage on both tps's i have and both are getting the same reading 4.7 volts on both when i measure the 2 outer most wires. so its reading wide open when my tb is closed. but y r both sensors reading exactly the same false reading no clue. my guess was the comp. so im in the process of ordering a conversion harness to obd1 with a chipped p28 seeing if that will help but i dunno im hoping that some 1 has had the same problem and can help me out cause im pulling my hair out on this 1 i tried just bout anything and nothing wants 2 work
Re: car chokes itself when i hit the gas (ls98hatch)
ground by the thermostats housing....the same thing happen to me check your ground and reset your ecu..check for cel its in limp mode....
1337 Si
05-24-2003 01:36 AM
