Can't shift well after clutch installed??
I am running ACT Heavy Duty PP with Action unsprung 6 puck
the break in period has been a week
i can't really shift well... in all gears...
it's fine SOMETIMES.....
then sometimes when i start, i can push in to first, i let the clutch go and step on it again, still doesn't work.. strange.. then after a few try, it's fine...
it usually happens when i go into third and fourth...
something wrong??? my tranny oil??
Re: Can't shift well after clutch installed?? (xbird)
need more info. on ur tranny..most recent tranny s use a 30w oil..dont use a syn. ..also, did the installers or u adjust the clutch to specs. after the install?..maybe want to check the specs. again after the break in period
Re: Can't shift well after clutch installed?? (rookie2nr)
i did bleed it...
i think it happens when the car is cold.. it's all fine when the car is hot...
i use HOnda MTF....
i didn't adjust anything... i thought i didn't need to...
i use HOnda MTF....
your master cylinder may be bad. thats probably why it doesn't help when you bleed it, b/c air is just getting right back into the system. and if it is, just go ahead and replace both the master and slave at the same time. i had to get these new when i got my swap done.
Re: Can't shift well after clutch installed?? (BlackDeuceCoupe)
i am not sure if u know
but my sohc is turbo
and that's a very very good setup from all the experienced ppl
maybe u are talking about N/A
I haven't had a problem with driving a 6 puck clutch. Neither have my friends. One of my friends was even driving a 4 puck. None of us were complaining about it. It seems very streetable to me. I'm so used to it that it feel stock to me. So forget what BlackDeuceCoupe says.
...forget what BlackDeuceCoupe says...
Yeah, don't listen to BDC...
EDIT> hmm... that wasnt the picture... LOL
[Modified by iviZeRoCooLivi, 2:04 AM 9/1/2002]
HT White Ops
Re: Can't shift well after clutch installed?? (14eight)
You burger flippers got him into this jam. You get him out. I'm deleting my posts.
Later
P.S. Thanks, iviZeRoCooLivi...
Hahahahaha! Whatever!
Later
i did bleed it...
i use HOnda MTF....
i use HOnda MTF....
only when the motor is cold?...thats call d balky shifting among the DSM croud..its when the fluid is to slippery to engage the gears..then when it gets hot i begins to shift more smoothly...i use a GL-4 70w-85 gear oil in my transmission...and most of the guys around here use a straight 30w oil..slippery is good for motor but bad for transmission..tranny s need the friction for the gears to engage
habanerored06si
Honda Civic (2006 - 2015)
16
05-17-2015 04:07 PM
13DevilsCamry
04-08-2005 07:53 AM
