Can't remove sun visors. Bolts seem threadlocked.
I'm trying to remove the sun visors (interior, not exterior window visors) and I'm failing miserably. http://images.honda-tech.com/set1//smile/emcrook.gif The screws for the hooks that latch the visor came out no problem, but the screws holding the actual visor to the roof liner won't budge at all. I'm a strong guy, but this is retarded. I've tried using a torx and a flathead. Nothing. Does Honda threadlock them from the factory? Has anyone experienced this or know how to remove them?
. EDIT: I tried using liquid wrench and still nothing... https://honda-tech.com/forums/images...es/emdgust.gif Modified by transpar_nt at 4:44 PM 8/10/2005 |
Re: Can't remove sun visors. Bolts seem threadlocked. (transpar_nt)
use the right size screwdriver and put vice grip pliers on the handle. push as hard as you can on the end of the screwdriver as you hold the vice grips with the other hand and turn. if that don't work try the same thing, but jerk it quick and it should snap it free
impact driver - $7 at harbor frieght, i use mine all the time, works like a charm
http://www.harborfreight.com/c...37530 |
Re: (smokee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokee »</TD></TR><TR><TD CLASS="quote">impact driver - $7 at harbor frieght, i use mine all the time, works like a charm
http://www.harborfreight.com/c...37530</TD></TR></TABLE> I was just going to say that. Excellent tool, I use it almost every day. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (JDM-97CX)
https://honda-tech.com/forums/images/smilies/emthup.gif I have one and it works great on the two screws that hold the rotor on, although it works even better with heat but you wouldn't wanna torch your headliner or would ya?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">I'm trying to remove the sun visors (interior, not exterior window visors) and I'm failing miserably. http://images.honda-tech.com/set1//smile/emcrook.gif The screws for the hooks that latch the visor came out no problem, but the screws holding the actual visor to the roof liner won't budge at all. I'm a strong guy, but this is retarded. I've tried using a torx and a flathead. Nothing. Does Honda threadlock them from the factory? Has anyone experienced this or know how to remove them?
. EDIT: I tried using liquid wrench and still nothing... https://honda-tech.com/forums/images...es/emdgust.gif Modified by transpar_nt at 4:44 PM 8/10/2005</TD></TR></TABLE> yeah use an impact screwdriver. I hope you didnt strip the screws trying to take it out. Damn, did u get liquid wrench on your headliner cloth?? https://honda-tech.com/forums/images...es/emdgust.gif |
Re: Can't remove sun visors. Bolts seem threadlocked. (xtremeazian)
no, i was careful to not get any liquidwrench on the headliner. I put the straw thing on the screw and held a paper towel on it before i squirted. The screws aren't stripped or wrecked and I did use the correct size. I guess I'll be buying myself an impact driver. thanks guys.
