cant pass smog need help
i own a 94 civic ex with a b16 but fails nox really bad....any suggestions ....
rpm co2 o2 hc co no
max gp meas max gp meas max gp meas
15mph 2231 12.6 2.5 92 281 252 .55 2.05 .68 716 1961 2813
25mph 2468 13.7 2.1 57 231 65 .54 2.04 .34 764 1761 1053
mods i have are:
aem cold air intake
skunk 2 intake manifold
dc 4-1 headers
stock p30 ecu (94del sol b16a3)
using 91 octane
have done a fuel service
changed plugs wires cap & rotor....
wanted 2 run stock ls exhaust manifold and oem cat....but dont know if it will help or work....
have also tryed stock air box and stock intake manifold same readings .....any help really appreciated need 2 register my car.....
rpm co2 o2 hc co no
mods i have are:
aem cold air intake
dc 4-1 headers
using 91 octane
Re: cant pass smog need help (94ej1b16)
I got your email and emailed you back, theres more questions in that and you could email me again if its easier for you.
By fuel service what exactly do you mean? Because your problem looks very much fuel related (running really lean for a smog test). I would check to make sure your fuel filter isnt clogged or your hard lines are not corroded. Another thing if you can get a fuel pressure reading. Make sure your getting enough pressure to the rail (42psi) because this could be a dying fuel pump.
Does the car act funny when you drive?
Re: cant pass smog need help (Luserkid)
car runns very strong......if i get on it.. it will respond....and that fuel service i did was a type of sea foam...
ok so i went this morning for a pre test ...and it passed quick and easy what i did was put stock air filter and i borrowed a stock exhaust manifold and a good used cat...i set my timing at 14 deg...and pass that sniffer test .now i just gotta make an appoimnment to tha reff station and im on my way to getting my coupe b.a.r legal
JManny
04-12-2011 08:16 PM
Touch
10
10-20-2006 04:23 PM
