Cant get clutch engaged without pressing the pedal to the floor
So i got this little problema with my clutch/pedal and my GSR transmission, and i would like to see if theres actually somebody else with this or similar. i searchd but couldnt find the right solution. I cant get my clutch to engaged without having to press the pedal all the way to the floor.
Details...so i already bled the system multiple times with no success, both master and slave changed. Release bearing changed, and i also adjusted the pedal like the manual says to, and still nothing.
One thing tho, when its at idle, i can hear a little noise coming from inside the transmission which seems to be clutch-related because it goes away once the pedal is pressed. but even with that noise, and sinking the pedal, the car still drivable, not grind, pops or nothing.
*As of today, i can adjust the pedal so that theres no noise at idle, BUT it wont let me put it in gear, sorta like i wasnt pushing enough.
Any feedback will be much appreciated, thanks.
Re: B***series Clutch!
sound is probably just the transmission turning while in N. as far as bringing the pedal up some and you already fully adjusted it and bled everything? im clueless of how to get it higher.
Your going way over the top with this one. The noise is the bearings inside the transmission. It's fairly common to have these fail, these parts are getting old...an don't last forever. My recommendation is to pull the trans and have it rebuilt. Having a fresh transmission is a wonderful thing.
dtran002
10-10-2013 08:55 AM
gnarlycs
11
06-10-2012 05:19 PM
95hbMatt
Transmission & Drivetrain
10
07-28-2011 01:17 PM
